Oyeve
Hi all. I have a Sony DRU-510A dvd burner that is rated at DVD-R 4x, DVD-RW 2x, DVD+R 4x and DVD+RW 2x. I recently bought a 50 pack spindle of Memorex DVD+R media and several days later I noticed it is rated at 8X and the top label has a warning that some manufacturers may require a firmware upgrade before using the discs. Sony is listed and when I go to sony's website for info on my drive it doesnt say if these will work but it also doesnt say that it wont. The only sure thing sony say is that DVD-RW 4x wont work! Does anyone out there have the Sony DRU-510A and use DVD+R 8x media successfully? Please let me know asap as I need to encode some stuff and I need to know so I can return these if they wont work and get compatible discs! Thanks. 🙂
