Help Configuring HTPC and Onkyo TX-SR503 please
vektor5
I just got everything but the sub and am exploring how everything works. I'm new to all of this and am confused.
I bought th X-Mystique as per suggestions as the Dolby Digital Live encoding sounded necessary for gaming. It seems to me now as if perhaps the reciever does this encoding also via PLIIx and perhaps I would have been fine with My SPdif out...but I digress.
I am connecting to the reciever via Toslink optical. So far I've only tried music but if I enable 5.1 Encoding on the card it doesn't use all 5 speakers or surround
If however I use PCM 2 CH at the card level then all my surrounds seem to work at the reciever. I guess my question is which are the optimal settings for me? Also I have a choice of 44/48 or 96khz out all of which work but I'm unclear about the advantages/disadvantages of these.
It seems as if I encode at the card and used the direct setting at the reciever it would work but it doesn't. The reciever recognizes what I'm sending it (PCM or Dolby) but will only do surround with the PCM so far. I've only tried mp3s so far but I understood that The DDL would encode that to surround (PLIIx Does this just fine)
Please excuse my ignorance
I'm very happy overall but would really like to get the most(use my equipment to it's best advantage) out of my system, meager as it, it's a huge upgrade from my 2.1 monsoon mm1100's. Any and all advice greatly appreciated. I'm also planning to game and watch movies with this setup.
Try a game with DDL selected and see what happens.
Did you get the drivers off this site?
http://www.hidiaudio.com/download/index.html
I recently found out that from a 2 channel source a DDL option will actually produce a very weak signal for center/surrounds as well as the FL/FR that I thought it was only doing.
For music, stereo is where it's at. Send PCM to the receiver and then set your receiver to just do stereo. If you really want to get surround sound going, try 7 channel stereo or some kind of prologic/DTS neo6.
Matrixing just sounds bad.
If you really want multichannel music, you ought to buy some SACDs or DVD-As.
Stuff that gets upmixed in no way sound pleasing, unless the concept of "all channels blaring" is really something you prefer over sound quality.
