After reading the "cable management " thread i decided to rewire my system (one in the sig), routing many of the main lines to the back of the case. Here is the big issue, i did NOT turn off the PSU (I/O button). I tuned off the computer, detached the power cable from the computer, leaving it attached to the surge protector. Rewired (wearing an anti-static wrist band) and reattached the plugged in power cable to the PSU while in the "I" (on) position. Now, nothing happens at all when i press the power button. None of the wires are severely bent, nothing seemed to have gotten pulled out. And yes, i reattached BOTH of the mobo power cables.
Here are my questions:
Is reattching the power cable like i did likely the casue of this? What did i do? Fry the mobo? Everything?
To rule out the case wiring, can i somehow directly wire the to power switch pins together, or is that not good to do?
What elese could it be? Would clearing the CMOS help with the mobo jumpers? I worked carefully and really the only thing i did was change he path of some wiring.
BTW, the Power LED has blinked, i believe when i press the power button, but not always. I have an old dell to play around with, will test my PSU with that system to see if its the PSU if there is not another fix.
Please Help
-Chris
Please Help
-Chris
