For a while now, I've had a 450 mhz computer that was very loud. I got myself a nice case of tinitus by using it too much, so I had to start putting paper in my ears to keep the sound out. It helped a bit, and I could endure it for a couple of months. I built a new computer yesterday, a p4 2ghz, 512 mb ram, geforce ti 500, sb audigy.
It sounds even worse. When I start it, it's not so bad. I can live with a couple of fans, but after a while it starts to sound like a low frequency tone generator. It seems like some kind of resonance builds up inside the case, and after a while it becomes unbearable. I shelled out almost $3000 for the equipment in it (hardware is expensive in Sweden). I paid $300 for a noice-control case (www.noicecontrol.de). It has a 1 cm thick layer of noice-absorbing material inside the entire case. But does it help? No.
In school, we have 20 1ghz p3:s. When all of them are turned on at the same time, they make about half as much sound combined as my new 2ghz makes alone.
I refuse to accept that I'll need to have paper in my ears as soon as I'm going to use my computer. After a while the sound becomes unbearable. Is there NOTHING I can do? I've bought extension cables, so the computer is about 4 meters from where I'm sitting, but it doesn't really help at all. Is this really normal?
Any help would be appreciated..
