HELP! computer is not entering windowsxp
BeLikeMiKe716
I am able to install windows and such but as soon as it gets past the windows logo screen with the progress bar, it shows a blank screen. I press the power off button and it turns off as it would be shutting down windows but i still dont see anything. Is it motherboard/ram? i dont know how it would just start doing this. Never really experienced failure until now.
bwatson283
1,062
can you get into safe mode? If you can, go into msconfig and select the SOS startup, and if it is a driver failure then it will hang when loading that particular driver.
BeLikeMiKe716
how do i get into safe mode?
also... wouldnt it not matter if i just reformatted since i dont have any drivers on it yet?
i reformatted couple times with different hdds to see what the problem was
BeLikeMiKe716
just to clarify:
i turn on the computer
it goes to the windows logo and the loading progress bar... and then when its done... its supposed to start windows and such but nothing shows up....
bmf2442
23
To get into Safe mode, hit F8 repeateldy before the Windows Logo screen. I think you have a problem with one of the automatic startup items. So, when in safe mode, to go start>run>type msconfig and click on the startup tab. Uncheck everything from that list and restart normally. If it works you know that windows is having a problem with one of those programs. Then just go down the list and check each one and restart. Do that until you reach a point where the problem happens agian. Once you find the culpret research the shit out of it online.
imported_Baloo
1,782
How much time is it setting on that blank screen before you power it off or reset it? is there any Hard drive activity; is the HD LED flickering? I ask because it's normal for a few seconds to pass with the screen blank at that point, and on the off chance that you are only giving it a couple seconds rather than waiting.
WildHorse
5,006
Do you have more than 1 HDD?
If you do, then boot into bios and make sure you set it so the correct HDD (the HDD that has the logical drive where your OS is, probably your C: drive) is set as the first boot device.
cubby1223
13,518
42
86
That's usually when the display is set to a resolution the monitor cannot handle. At the XP startup menu, select vga mode, then adjust settings if xp loads then.
BeLikeMiKe716
CUBBY THANKS SO MUCH...
I pressed F8 and then chose the VGA mode and it worked... the resolution was really low but it works... I tried changing the display settings and then it went black again...
do you think its because my video card is shot?
I think i may have now overloaded it because it actually happened a few weeks later after i attached a 30 inch monitor to it...
if you think i only need a new vid card then recommend me one?
RadiclDreamer
8,622
40
Try reinstalling the video card drivers before you go all the way thorugh with buying a new card.
BeLikeMiKe716
ok so i did everything... reformatted and then reinstalled the drivers and it seems to be working fine... thanks so much
but during one of the restarts, it froze at the windows logo loading screen... this happened before also but I was able to restart again and it went back into windows but im afraid the problem isnt really resolved or dont know what would make it do that.
alll your help is really appreciated
thanks so much
