arun_halley
I am facing a weird problem. Bought HP Pavilion Desktop E9240F (refurbished) 6 months ago. Worked fine till yesterday. Was downloading a trusted zip file when it suddenly restarted. It then gave me a blank screen with a blinking cursor at the top left corner. I think it is not even loading the MBR. Basically it brings me to the screen which says Press <CTRL +F> to enter RAID Option ROM utility... and then it goes to the blank screen with the blinking cursor. Can access only the F9 (system check) and F10 (BIOS setup) Screens. F11 - system recovery takes me to the blank screen with the blinking cursor. Out of HP warranty.
Tried to trouble shoot and here is some information that might help.
There is only one hard drive (1 TB)
In the BIOS setup, it is set to
SATA1 Controller - Enabled
SATA Controller Mode - RAID. (options are IDE, RAID, AHCI)
Ran the standard F9 test - everything is clean.
Then set the SATA Controller Mode to IDE. F11 works. Great! So then went into the recovery console. Tried the Self Fixing Errors console. Ran clean. Then Tried to reset it to a previous restore point. Goes through the entire routine without a problem and at the end says cannot restore to the previou point. Then when i try to boot windows, it shows me the Windows flying logo and then the computer restarts.
I feel it is a hardware problem. If anybody can throw some light and guide me that would be great. Or if additional information is needed, i can provide it.
Thanks
Arun
Thanks
Arun
