HELP ! COMPUTER CRASH AFTER 5 minutes
fourier
System Spec :
AMD Athlon XP1600
512 MB DDR RAM
GeForce3 Ti200
Here is the situation...After I played world of warcraf around 10 minutes or 15 minutes my computer crashed...its not just ordinary crash but the screen just freezes and the sound card emits a contanst "beeeeeppppp" sound...pressing Ctrl+Alt+Del does not work and the system just practically crashed
This problem only happened if I played games that requires high spec systems such as WoW, age of mythology, Counter Strike....etc....but sometimes when I open simple programs such as flash the same crashing method occured....the crashed occur randomly when Im playing a game...sometimes It took an hour before it crashed but sometimes it took 5 minutes....When Im just browsing and chatting this crash never occured...it only occured when I played a game...This is not a software problem cause I formatted my computer 3 times and the same thing still happened...there is definitely something funny with my memory or my video card...
I suspected corruption on my main memory or the video card memory...but im not really sure which one but it definitely crashed my motherboard cause my soundcard, which has nothing to do with anything, also crashed and emit a constant "beeeeeeeeeeppppppppp" sound...So Im waiting reply from the expert here before i take action
help !!
It sounds like the memory to me. Try going into your bios and lower your memory timings a bit to see if that helps the freezing. The only other thing I could think of that it could be is the PowerSupply.
