Before I get to the problem, please don't get into nVidia vs. any other maker because it won't address my problem. I have to use an nVidia board because, from a lot of searching and experimenting, they are the only maker whose chipsets still support the old DOS VESA video standard, which I need to use for a couple of legacy apps.
My motherboard is a DFI AD77 Infinity (VIA KT400 chipeset), and my vid card is an older nVidia card. I tried a couple of cards from different makers with different levels of the current chips. They all seem to work with the native nVidia drive, but theyl fail when I try to run some of my old aps from the command line, even though my older nVidia cards work fine.
I know it isn't the newer cards because the same cards work in the same apps in a couple of other machines. I've tried various drivers and BIOS updates, but nothing helps my otherwise great machine.
Anyone have any ideas, or am I going to have to accept the fact that this board just doesn't support the cards I'd like to use?
TIA
TIA
