Help choosing the right motherboard for gaming
guyf1712
10
Hi,
I'm willing to buy a new computer soon.
I search for the right motherboard for my system.
CPU: Intel Ivy Bridge Core i5 3570K Socket 1155 6MB 3.4Ghz Tray
Graphic Card: Sapphire HD7850 OC 2GB GDDR5
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL
I'm not going to do OverClocking. only the graphic card is OC.
What MotherBoard works the best with this ingredients?
Thanks,
Guy.
utahraptor
1,067
237
I would suggest either of these two:
MSI Z77A-G45 - On Sale for $114.99
http://www.newegg.com/Product/Produc...82E16813130645
ASRock Z77 Extreme4 - On Sale for $124.99
http://www.newegg.com/Product/Produc...82E16813157293
Pick the one that is most pleasing to your eye :)
utahraptor
1,067
237
The ASUS P8Z77-M PRO is a micro ATX solution if you are taking form factor into consideration. The two I linked are ATX FYI.
Tintan
22
Bro i never point on your suggestion given to OP. You have given the best one, Their is no deny it. But i can also suggest him with my own thoughts. Hope you don't mind it.
utahraptor
1,067
237
I don't mind at all. I think he should link his case so we know what will actually fit :)
Tintan
22
Yup. Let's hope he can post some pic of his case. Until then our suggested MOBO is just a waste.
utahraptor
1,067
237
I think he is asking what kind of case you have. If you have a micro ATX case you don't want to go with an ATX board.
utahraptor
1,067
237
People generally select the micro ATX if they are using a small case for easy transport to and from a LAN party for instance. The only draw back of having is they usually have less PCIe slots. If you are not using multiple graphics cards or other PCIe cards then it is not really an issue. If your case has a side window panel (yours does not) it may look strange having a smaller board in a normal sized case.
