Help Choosing Surround Sound Wireless Headset!
Killer Nads
16
Hi Guys,
I spent hours yesterday evening looking for the perfect headset! All in waste as i couldnt find one that supports everything i require.
Basically, i need a good quality surround sound (preferably 7.1 or at least 5.1) wireless headset that connects with the PC to play games, but should also be able to connect to the AV Receiver for movies/console gaming (dont need mic for console gaming - just the headphone to listen to surround sound audio on late nights). A huge bonus would be if it comes with a charging stand! Also Bluetooth enabled would be another plus!
Im having trouble for any headset to match the above description! Do you know of any? or know where i could look for one?
I was going to order the Corsair Vengence 2000, as that atleast does the PC part correct, but then realised its a USB enabled wireless headset. Hence, im not so sure if this will connect with an AVR and still offer surround sound such as dolby and/or DTS.
I was then considering going for the Sony MDRDS6500, which would connect with the PC and the AVR to offer 7.1 audio in HQ! However, then i would be missing a mic, which im sure would be useful and needed for PC gaming.
The last headset i found was the Turtle Beach Ear Force Tango! This is a branded Call Of Duty exclusive headset, which i found is also the best quality of all the turtle beach headsets. It offers both a wireless headset experience for console gaming and for PC. One massive feature is that it has bluetooth aswell, so i can use it with my iPhone. This is great for when I'm immersed in the Oculus Rift VR kit and i receive a phone call, i will be able to hear the call within the headset.
However, im not so sure on the audio quality of these headphones. Some reviews were stating its only average and has very low sound, others were saying that its a problem to get working with a PC as you need both a bluetooth dongle and a sound card in your pc to get surround sound to work cause you need the Dolby Digital Live installed?!
On the PC im going to be using the 7.1 onboard motherboard sound card.
Hence, im back to where i was and completely confused as to what would work best.
Alamat
683
9
I've been looking at these. A little more coin but seem to fit the bill and it will be great for gaming and HT use.
Killer Nads
16
Yes i did see those, problem i saw was that they are battery operated and not rechargeable - im not sure if thats a good thing or not!
The one i was talking about in my post above that are similar are these (Turtle Beach Tango):
http://www.amazon.com/Turtle-Beach-C...f=pd_sim_vg_25
They are rechargeable, but im not sure what else the difference is between this and the px5's ?
Alamat
683
9
Yup, I guess that would be one difference plus lots of other features than you might be able to use but I guess it depends if you think that is worth another $70. Reviews seem pretty good too. Personally, I think I'll save up for the Tangos.
Killer Nads
16
Im having a real issue with headphones!
I purchased the Turtle beach Tango wireless headset last week for my new system (to arrive end of the week).
However, i thought i would try it out on my few months old htpc system, however i can not get any sound output from the windows machine onto my headset!
I plug in the optical cable (realtek) from the htpc motherboard to the wireless headset receiver. I select the headset in the Audio devices list on the pc. But playing a video in VLC outputs no sound, wierd thing is though if i try play individual sample files under audio devices to make sure that the sample rates work, the tests produce sound to the headset! However, if i do a test sound of the whole audio device, i get nothing!
Right guys i actually found this guide here:
http://www.turtlebeach.com/support/entry/830517212/
It says to enable surround sound audio my sound card has to support Dolby Digital Live!
Is this usually found in onboard sound cards in motherboards? or not really? Im also wondering if my new motherboard will support this or not? Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
I don't really want to purchase a separate sound card either! So my only other option is to return the headset (if they take it back even) and get something else!?
Any suggestions?
Thanks
