Help choosing mods for Lian-Li...
Mrvile
I'm looking at the Lian-Li PC-07 case at performance-pcs.com and you get to choose from a number of mods. Which ones would be best? Especially blowholes, which size and how many should I get? Going to be running dual Opteron 240s, maybe a little OCing but without the U-wire mod. Thanks.
I have a Lian Li PC60 USB case. Definitely get the 120mm top blowhole mod. I installed my own and it really improved overall case temps dramatically.
Ok that's what I was planning on doing. All the different sizes are the same price, so why not get the most for your money. I'm probably also gonna get the side window 120mm as well, then my case will be an f ing turbine.
What about the the Lian-Li temp sensors? They have dual temp screens which work perfect with my dual cpus but the actual thing looks kinda crappy. But who knows.
And finally, what's a rocker switch?
