there is none.
i just need to find one with removable dust filters because he cleans his filters every 2 weeks, i suggested buying some, but it would be too much hassle to take out fan, remove filter, etc.
I don't really see why the filters need to be necessarily removable though. For example my R3 filters are easily accessible from outside the case with a vacuum cleaner, they're integrated into the case so they don't need to be removed.
Anyway, I'd recommend the Corsair 550D. Why? It's Corsair, it's extremely quiet, and the front panel has one big filter for both fans and it's removable.
