- Nov 29, 2003
- 61
- 0
- 61
Hi everyone,
My daughter is in charge of purchasing a laser printer that will be used by the physics department at her school. It will be used for experiments, and their limit is $1,000 (total purchase price). Of course they?d prefer a lower purchase price. It must be a high resolution printer that prints block lettering and can be programmed in PostScript. Since it?s a physics lab, they?ll be printing a lot of graphs and hologram type images which reminds me of the old punch cards for main frames after they have been coded. (For those of you who remember such.
) To give you an idea of one use of this printer, here is a project they?re doing: A pattern will be printed in PostScript. It will then be resized either by photocopy machine or a photograph made using lithium film. A neon laser will be used to illuminate the intensity pattern of the image. The patterns of multiple images will be compared.
It doesn?t have to be a color laser, but the salesman at our local Staples told her that color is best. He also said that once you get to 600 x 600 resolution in black and white, there is no difference when printing in black. So, a 1200 x 1200 isn?t really ?better.? If that?s true, then what is the difference between 600 x 600 and. 1200 x 1200 strictly in terms of black & white printing?
The department hasn?t requested a color printer, and she?s not opposed to getting one within their budget, but as you see, there are questions about which to get. She?d rather get a better quality black and white, unless what the salesman said is true.
I hope I've explained our needs clearly. :/
Any suggestions?? Thank you in advance!
