Help Choosing a Graphics Card
shyamhwp
I desperately need some help in choosing a graphics card for my custom build system
i7 6700K processor
Z 170-AR mobo
Hyperfuryx DDR4 8 GB RAM x2
Samsung 850 EVO SSD 120GB - Boot Drive
Cooler Master 550Watts SMPS
The Main Applications are Adobe Photoshop,Cinema 4d, 3ds Max, After effects CC, Z brush - Modelling and Rendering - Entry or Mid level
I play games very rarely.
Pls suggest me a Graphics card in Geforce series rather than an Quadro series.!
Thanks a lot. Gtx 950 or Gtx 960/Gtx 970?...... Ans is Gtx 950 better for my application than Gtx 750 ti or Gtx 760?....Can you please explain me in details....Because i am going to go ahead purchasing by tonight.
Will it be ok for all the rendering and also match with the Skylake processor and motherboard. Power supply of 550Watts?
Hi guys, I'm looking for graphic card than that support 3D , 4D graphic designs and rendering for a reasonable price though! (a price range of 200-250 Euro may go to 350 if something worth it)? I work on Cinema 4D, photoshop and after effect CC (I don't play games though on my computer) I have i7 computer 8G(I may increase it to 16G) power supply at the moment 500W(480W) I also may buy a new one with 700W, I found one but is a bit too expensive for me, please let me know what you think : AMD FirePro W5100 Graphic card .
