help choose MB for micro-atx
SeanFL
143
I'm building a system that will be used for video & audio editing. It'll be in a micro-atx case.
Processor: Q6600.
last year when I built a similar system, some folks suggested the Asus P5B-VM and it worked awesome. I don't have a need for a high end motherboard; just a stable one.
what's the equivalent this year? I'd like to stay with Asus, seemes very stable. It won't be overclocked; I would like it to have firewire and e-sata. I don't need onboard video; it just came with it last time.
Thanks much. Sean
Synomenon
10,547
The new "Asus P5E-VM HDMI" is going to be available in the US this month. It's available in the EU already.
SeanFL
143
thank you guys, thanks for all the links NXIL. If I did want to stay with asus (and didn't want to wait for the hdmi version)
do the choices seem to be P5B-MX (wifi?) or P5b-plus or P5b-vm se?
And since I'm going with the Q6600, does that lock me into the G965 chipset? (I don't know if I care either way, just wondering if I need to narrow my search to a certain chipset).
thanks again. Sean
NXIL
774
Dear Sean,
Q66000 does *not* lock you into G965 chipset--in fact, said chipset is on the soon to be discontinued list--I think it is the microatx requirement that is a bit limiting.
As for choosing motherboard: Newegg's search function is pretty awesome.
Go to this page, and click off your requirements:
http://www.newegg.com/Product/...ategory=280&GASearch=3
Quad core.....microatx....firewire, etc, and the search funtion will sort them out for you; then compare by price, and, with a grain of salt, user reviews.
HTH
NXIL
SeanFL
143
Thanks NXIL, I hadn't figured out how to get to their powersearch...thanks for pointing me that way. The P5B-VM wasn't listed correctly as being able to support a quad core (it does). With G965 heading toward being discontinued, what's the replacement? Is that the G33? Does it look superior?
thanks again. Sean
