I need to replace my TH7-II RAID mobo, and I'm going to put in an 845PE board. My concerns are these:
1) My HDDs are on the RAID controller (not RAID arrays, they are single drives, but using the RAID controller). When I change motherboards, there will be a new RAID controller. How to I set WinXP up so it will load the drivers for the new controller, and allow me to switch motherboards?
2) How do I go about updating the chipset drivers? Assuming I can resolve the above problem, will it be sufficient to simply run the intel chipset untility and install the newer drivers?
3) Will doing this upset the stability of my system? Currently, WinXP (pro) is very stable, and i have no problems.
Thanks for your help 🙂
