Is this your first time building a computer? If so, then I'd probably suggest the basics. Did you use stand-offs when placing the motherboard in the case(you don't want to screw them in so tight, that may ground the motherboard)? Did you connect the power supply to all the slots on the motherboard (a 20-pin main ATX connector and a 4-pin ATX connector)?
