- Jan 27, 2000
- 773
- 0
- 71
I have a Celeron-2 600MHz running at 900MHz at 1.70v. It's a cC0 chip that defaults to 1.70. It is mounted to a generic slocket that is in my P3V4X. I am using a FOP-32 to cool it, with some Arctic Silver slid in there. With the case CLOSED, the ambient case temperature is around 30 degrees, and the CPU runs at 45 degress while idle. Under 100% load, it tops out around 58 degrees. This seems a little high to me. The Asus board reads the thermal probe built into the Celeron core, so perhaps that's why it's higher than what others are reporting? If that's the case, what is the equivalent "surface' temperature?
Thanks,
Aaron
Thanks,
Aaron
