i got a pionner slot load dvd drive and a cd is stuck in it. i pushed the open button but nothing happened and i tried another program to eject it also, and nothing happened.
right see the little very small hole on the front of yer cd rom drive get a paper clip and open it up shove it in the whole and try to find a bit of pressure if you know what i mean the paper clip could miss the eject system so just wiggle it till you find some pressure and push... its a manual release system for cd rom drive s
I remember when the manual eject feature didn't exist. My friends CD Rom would always go on the fritz and eat cds... we literally had to pry it open with a flathead screw driver 🙂 Don't do that though! Use the manual eject 😉
