hipertec1
Hi, I have my house ran with Cat5E wires when the house was built. One of the wires going from my router to my home switch is not detecting #8 wire (Brown?).
So 7 out of the 8 is reading thru my ethernet cable tester. When it gets to #8, its not showing and then starts over again from #1 - #7 wires. So I think there is a break on this brown wire?
When I plug this cable to my router and the other end to my switch (100/1000), there is no power and not connecting. But when I connect to my Linksys Velop Mesh router with the built-in ethernet port, the switch reads the connection but on 100mbs speed.
Does anyone know how I can fix this to get full 1000 speed? I need this cable to be at 1000 as it will go from my router to my switch at a different part of the home and unfortunately, I cannot replace the cable as its wired when the house was built.
Im hoping there is a way I can wire it and not needing to use all 4 pairs and/or a solve so I can get my router connected to my giga switch.
