tortillasoup
- Jan 12, 2011
- 1,977
- 3
- 81
ok, here's what happens...
i put the car in neutral and step on the gas, minimal whine... gets worse at higher rpms, though.
i put the car in park and step on the gas, minimal whine... gets worse at higher rpms, though.
i put the car in drive and step on the gas, there's a loud whine that gets louder as the rmp increases.
i have a 2000 volvo s40. what is the problem and will this cost a lot to fix?
Run an alternator test... Go to autozone or some place like that and have them do a free alternator test on the car. First test the alternator with no electrical loads running, see if it passes. If it passes, then try upping the electrical load by turning on something like the high beams, and the blower fan to max speed (don't turn on the A/C). If it passes under these conditions as well, then maybe it's something else.
Another thing to keep in mind is to try to turn on the high beams, cycling them on and off and see if it changes the pitch of the whine. If it does, it's likely your alternator. An alternator with failing diodes will create a whining noise that sounds similar to a supercharger.
