Help: Car adapter kit for Rio Volt?
chien
Hi, anyone know where I can get the car adapter kit (DC power+cassete adapter) which will fit rio volt mp3 cd player? Thanks for help 🙂
Chien
Thanks for reply. I just went bestbuy today. They have car kit made by Sony ($29.99). However, I was told that this one won't fit the Rio Volt and there are many people returning this one. Is this true or what? The major problem is the DC adapter not the cassete adapter as they told me.
Thanks again for your help.
I had one similar enough lying around that worked, but you should try radio shack, I know once I had to get an adapter and they merely found the right voltage converter and then found the end attachment that fit and put the two together, it worked very well.
