Help! Cant send results to Seti!
aphoenixrises
I am getting fatal error message. The only thing I have done differently is to change my IE to 6.0 yesterday. Could this be the problem or is seti down?
Thanks
Joan🙁
Point to one of the TeAm caches you can use mine at 216.133.27.135 Port 5517. You will be able to get WUs and send your results up. As soon as the problem with Berkeley clears the cache will send the results up for you.
SetiTeam is running if that makes any difference. It wasn't earlier.
ERRR....scratch that...it just gave an error "lookup failed" 🙁
Thanks for the update. I thought it was my systems going haywire. I am ok for now and have a cache on seti monitor to see me through a few days of this.
