HELP Can't POST past 140mhz FSB on P3V4X
Viper GTS
37,840
204
The FSB looks pretty low for a 133 MHz P3...What's your memory set at? You're not using the +33 option, right? CAS2, or CAS3? You might try using the -33 option for the memory, to run it slower than your FSB. If you can post at that, you know your memory is holding you back...
Viper GTS
jkersenbr
1,691
I've heard that it helps to put a different heatsink on the P3V4X's clock generator chip. It's the chip up between the DIMM's and Slot1. Something on the order of a video card heatsink with thermal paste in the center and a dot of superglue on each corner should help.
Good Luck.
jkersenbr@flashmail.com
Generalen
709
Try post at 146mhz it worked for me but not 140.
ASUS P3V4X
P3733@803 standard heatsink and fan
CL geforcePro 150\350
256mb pc133 cas3 :(
20gb HD
Pioneer 10x DVD
SB live player
TiberianGold
37
To Generalen: I have tried to POST at 142mhz but it won't work, but I will try, do you have any info on how my RAM settings should be set?
TiberianGold
37
To Generalen: Thanks, I got it to post at 146mhz. How many times should I run 3DMark2000 before I can considder it stable?
ASK THE COMMUNITY
