HELP! Can't Open Java Console!
Baasha
1,989
20
Guys,
I just installed the latest Java JDK (including JRE and Java SE 6) for my system (Windows 7 x64).
I can't get the console to appear and/or open!! I went into the Java Control Panel (via Control Panel>>Java>>Advanced>>Java Console>>"Show" Java Console) and enabled the Java Console but it doesn't show up in the Task Bar (coffee mug icon)!! I also tried enabling it via IE8 and Firefox 3.6.2 which has a "java console" option under Tools but nothing happens when I click on it!
I'm a complete novice with java and I'm trying to learn it on my own. Please help me!
Thanks in advance!
Good4Me
46
Are you on a webpage with a java applet? It only shows up when the java plugin is in use.
Baasha
1,989
20
?? I want to start writing a new Java program (tutorial etc.). How do I do that? For example, if I want to write a HTML or CSS program, I just use Adobe Dreamweaver CS4. I thought we have to use the Java Console for writing Java programs?!?
Ken g6
Moderator
Dec 11, 1999
16,634
4,562
75
The Java Console is for debugging a Java applet on a web page. To create a Java program, I suggest either Eclipse or Netbeans.
Baasha
1,989
20
Thanks for that!
Which one do you recommend for a novice? I see that NetBeans is offered on the Java (Sun) website itself.
Any one in particular you recommend?
Ken g6
Moderator
Dec 11, 1999
16,634
4,562
75
Personally, I'm used to the command line and GVim, so I just used those when I started Java programming. Eclipse never quite suited me. I finally had to use Netbeans on the job, and it grew on me. I liked the easy access to Javadocs.
However, Eclipse seems to be the most popular Java development environment out there. So I suppose you should start with it.
Baasha
1,989
20
Thanks!
I actually uninstalled the JRE and reinstalled the one from their site which includes the NetBeans 6.8. I played around with it and it seems quite intuitive.
I will practice with this and try out Eclipse in the near future.
Leros
21,867
7
You can also code in a text edit. Just save the file has a .java file.
Then on the Windows command line compile with "javac filename.java" and run with "java filename".
I prefer a text editor and command-line compiling for simpler projects where I don't need to step through the code or use breakpoints.
