K KenG Member Jun 17, 2000 73 0 0 Sep 24, 2000 #1 I put a DVD into the AOpen 1640 Pro (a slot type DVD-ROM) and can't play anything "no disk" type message. And, worse, can't eject. There is no little hole to do it manually. And the manual is quite brief. Any ideas? Anybody? Ken
D Dritzen Junior Member Jul 2, 2000 6 0 0 Sep 24, 2000 #2 Try opening the Windows CD player and hitting the eject button. You'd be surprised how many times this has worked for me
K KenG Member Jun 17, 2000 73 0 0 Sep 24, 2000 #3 Thanks. But I found the problem <blush> I stuck the damn disc in the crack ABOVE the slot. Dumb.
