HELP!!!! Can't get case off of Gateway 300S!! Any help?
Waveslidin
297
I feel like a total moron, but I cannot get this case off of a Gateway 300S. Does anyone know how to do it that could give a quick hint or two? Much thanks!
mechBgon
Oct 31, 1999
30,699
Have you consulted the owner's manual? I downloaded this PDF file, which is apparently the manual, and it shows some helpful pics on page 193-194. Looks like you unlatch the side panel using the recess at the top, and it hinges down on its bottom edge. Hope that helps. :)
