HELP! CAN"T FLUSH, 3 PC'S
paf077
1,241
I now have 3 pc.s at work that won't transmit the WU's to my Q! :(
They're on dial-up, but 4 others are also and work fine. Every time i try to transmit, the client says it found the Q and then,
it goes to "sending result" and closes after 2-3 seconds. And no results are sent and none uploaded.
If I close Seti Driver and restart it and up the caches by 5 or any number, then they download the extra WUs.
But never send in the results. I have over 30 WUs waiting to upload and no cdr or zip on these pc's.
I tried to move the folders to another directory and try one at a time, but still the same.
Any way to get them uploaded??
Thanks everyone for your help!
Paf
Crazee
5,736
Paf,
Have you tried pointing to a queue outside your work to see if they will flush? You can point them to my queue if you would like at 216.133.27.135 port 5517.
TNOguy
246
A queue is something you can insert inbetween your client an Bezerkely that hopefully most of the time will be up and running and able to accept your upload and give you new WU(s) to crunch on! :)
The queue will then eventually upload to Bezerkely on behalf of you :)
Van
