Help! can dual-DVI card drive DVI and analog monitors?
Skypix7
I'm using a 2 19" CRT setup now for photoshop imaging, I'm an aviation photographer and shoot all digital now.
I'm figuring the Matrox G550 dual DVI will work for me, I've had great success with the dual G400 Max on my P4 rig.
Don't need gaming performance, just want to get a good 19" LCD and use my best 19" analog for the second monitor. Do you know if the card will power one of each or do I have to make the switch to all DVI?
thanks!:camera:
rbV5
12,632
FYI G550 DVI max resolution is 1280x1024, but IIRC they are DVI-I connectors, so the should run in analog mode just fine with the adaptors.
Skypix7
re:
thanks rbV5, not sure I understand your reply...Matrox dual cards set up each monitor individually, at least my g400 does, and the 550 has both analog and DVI outputs, but what I was wondering is, can I have one of each, analog and digital, hooked up?
I guess I'll ask Matrox, but anyone know of another card that will do this trick...until I can pop for another 19" LCD? :Q
rbV5
12,632
Originally posted by: Skypix7
re:
[/b]Link
Sorry, I didn't word that very well.
Configurations
VGA monitor/analog flat panel + VGA monitor/analog flat panel
VGA monitor/analog flat panel + TV
Digital flat panel + VGA monitor/analog flat panel
Digital flat panel + TV
