HELP!!! Calculus (differential equation) problem
Scrapster
3,746
Find the solution y= of:
y'' + y = tcos(2t)
Need to use "undetermined coefficients" on this one. That t in front of the cosine is screwing me up.
This is where I am:
(at + b)(dcos(2t) + esin(2t)) a-e are just constant coefficients with respect to t. I'm not sure what to do next. Do I distribute the (at + b), it gets pretty messy if I do.
anyone have suggestions?
Passions
6,855
Do dis:
r^2 + 1 =0 rite
=> r= +- i
Y(t)= (at + b)sin2t + (ct + d)cos2t
you know to do from there?
DesignDawg
DUH! The answer is 4. I thought it was pretty obvious. Dumbass. ;) [Glad I never have to take another cal class]
Ricky
DesignDawg
Scrapster
3,746
Bobby, I'm already passed that. I found the yh, homogenous equation. Now i need to find, yp, the like form of: tcos(2t) (ex. (at + b)((cos2t) + sin2t)), then find the 2nd derivative of it to plug into my first original equation.
thEnEuRoMancER
1,415
Homogeneous solution:
r^2+1=0
r=+-i
yh=d1*e^(it)+d2*e^(-ix)=c1*cos(t) + c2*sin(t)
Particular solution:
right side of equation: r(t)=t*cos2t is of the form r(t) = e^(at)*p(t)*cos(beta*t),
where a = 0, p(t)=t and beta=2
The particular solution for this form is:
yp=e^(ax)*sin(betax)*(Anxn+...+A1x+A0)+e^(ax)*cos(betax)*(Bnxn+...+B1x+B0)
the coefficients A1..An and B1...Bn are yet to be determined,
in our case a=0, beta=2, polinom p(t) is of the first degree, so:
yp=sin2t*(A1t+A0)+cos2t*(B1t+B0)
We must determine the coefficients A1,A0,B1 and B0 by deriving yp and inserting the derivatives into the differential equation:
yp" = sin2t*(-4A1t-4A0-4B1) + cos2t*(-4B1t-4B0+4A1)
so we get
y" + y = tcos(2t)
[sin2t*(-4A1t-4A0-4B1) + cos2t*(-4B1t-4B0+4A1)] + [sin2t*(A1t+A0)+cos2t*(B1t+B0)] = tcos(2t);
sin2t*(-3A1t-3A0-4B1) + cos2t*(-3B1t-3B0+4A1)] =tcos(2t)
the sin2t term on the left must equal 0, so
A1=0, -3A0-4B1=0, -3B1=1, -3B0+4A1=0
The coefficients are A1=0, B0=0, B1=-1/3, A0=4/9
The particular solution is therefore
yp=(4/9)sin2t-(1/3)tcos2t
And the general solution is
y=yh+yp= c1*cos(t) + c2*sin(t) + (4/9)sin2t-(1/3)tcos2t
