help buying mobo/cpu combo
FAS284
well its been a very long time (6 years) since I assembled my last computer and I've not followed cpu/mobo prices for a long time so I need some help/guidance for a budget (<$100-$125) system upgrade.
I'd like to know what a good (and cheap) mobo is out there that is loaded with a good onboard video chipset and audio chipset and will be compatible with a cheap cpu (please specify as well).
also, where is a good place to buy a cheap cpu/mobo online and/or B&M? Fry's seems to have some good selections but what about online vendors? Which ones do you trust for reliable mobo/cpus ?
Thanks!
Check outpost.com or Fry's electronics. Yesterday's ad had the athlon 64 3000 with ecs nforce3 socket 754 board for only $90.
i'm eyeing that one, just thought there may be others. how does outpost.com compare to fry's b&m? similar prices?
wonderful, thanks zap! but now i need to figure out how much dr2 memory costs. would like to keep my entire budget below $150.
how do these mobos compare with asus k8n or MSI k8ngm2-nbp? someone's offering me the k8n.. thanks to all of you for your advice. really helped me out.
In the end that would be your call.
Used is used. I won't buy a used mobo, its the most important part IMO, it alone decides how powerful, upgradable, modifiable, and expandable your computer can be. Everything could work great for a week and then your lan dies... or sound... no warranty = tuff luck.
One last attempt:
ECS RS485M-M (V1.0) Radeon Xpress 1100
AMD Sempron Processor 2800+ Socket AM2
$105 Shipped @ ZZF
If you need DDR2 ram, you can pick up a 512mb kit for as little as $50, 1gb kit as little as $80, and a 2gb kit for as little as $110(this one has rebates)
Don't forget that they released info that am2 socket will be compatable with am3 processors, but thats looking way ahead I guess.
PS. Someone tell me if my rig link in my sig is working plz.
(Edit: That mobo goes up 20 bucks after tomorrow 7/14, so if yer gonna grab one GET IT!)
