Question Help buying compatible RGB lights & Fan Frame for my rig
Kratos47
51
Hey Guys,
I need some help regarding RGB light effects I want to add in my existing system which was purchased in 2015.
My PC Specs are:
~MOBO: MSI X99A Gaming 7
~CPU: i7-5820K @4.0 GHz
~CPU Cooler: Swiftech H320
~GPU: MSI GTX 980Ti 6G gaming edition
~RAM: 16 GB DDR4 Corsair Vengeance @2800 MHz
~SSD: Crucial MX100 256GB ~PSU: Antec HCP 1300W
~NZXT Phantom 820
Obviously my MOBO is old and doesn't have RGB headers and I think i need some sort of RBG controller. My case is Phantom 820 that has one RBG controller on it already though but i wouldn't mind buying a kit with addtional RGB controller.
Now Fans i don't want to buy and want to use the stock ones with this LED frames instead:
Phanteks Halos 140mm RGB LED Fan Frame - Plastic Black (PH-FF140RGBP-BK01)
This will do the job but how will I manage its RGB effects? Can the coolermaster RGB LED controller control it?
https://mdcomputers.in/cooler-master-rgb-led-controller-mfy-rcsn-nnudk-r1.html
Moreover I see the coolermaster controller has an additional 2 slots. Can some LED strips added to it as well? Which LED strip is compatible? I've no idea about it. Please help!
After some googling though I think these 3 will work just fine:
Cooler Master RGB LED Controller:
https://www.coolermaster.com/catalog/coolers/rgb-accessories/rgb-led-controller/
Deepcool RGB 350 Strips:
http://deepcool.com/product/dcoolingaccessory/2016-03/12_4814.shtml
http://www.phanteks.com/Halos.html
Will these work together?
LOUISSSSS
8,770
54
I don't have an answer for you as I don't care for lights on my computer. But just curious. why do you want so many lights on your computer and lights of rainbow color? serious question
