Help buying a new Power Supply
ultimaxxl
7
Hello!
I'm building a new PC and i need your help to buy a Power Supply, the specs from the new pc are:
Intel core i5 750
MoBo Intel DP55WB
8Gb 1333 DDR3
500Gb HDD
Radeon Ati 4760HD
2 DVD-RAM Burner
Thx for the Help!
HOOfan 1
2,337
15
Are you going to overclock?
If not anything over 500W would be more than enough.
MagickMan
7,460
People talking about 650W+ PSUs when his system will barely pull more than 240W. Crazy.
Dude, buy a decent 450-500W unit from a good company and call it a day, try Antec, Corsair, or Seasonic. Hell, maybe even grab an OCZ if you can get a crazy deal. Sometimes you can find one for $20AR.
Rifter
751
i would get a 500W corsair or Antec. unless you plan on a huge GPU upgrade like 4890 CF, then get a 800w+.
TemjinGold
3,050
65
Hello!
Intel core i5 750
MoBo Intel DP55WB
8Gb 1333 DDR3
500Gb HDD
Radeon Ati 4760HD
2 DVD-RAM Burner
Thx for the Help!
If you don't plan on a major gfx upgrade down the road, the 400w Corsair would be perfect for you.
Infrnl
1,175
Newegg had an antec ea650 for $65shipped with promo code, but I do not have the email anymore, so I do not know if its still active. you would have to do some homework to find out
