Help building pc!!!
Status
Not open for further replies.
Joestat99
Hey im building a pc for the first time. Im looking to play minecraft, and some steam games like gmod. Also maybe some video editing. I have about $550 and need advice for some parts. This is what I came up with:
Cpu: Amd athlon quad core richland 760k 3.8 ghz ($78)
Ram: 8gb G.skill ripjaws ram ($68)
Gpu: Sapphire radeon r9 270x ($160)
Storage: 1 tb western digital ($51)
Psu: 500w Evga certified power supply ($39.99)
Motherboard: MSI A78M-E35 FM2+ / FM2 AMD A78 (Bolton D3) HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard (59.99)
Os: windows 8.1 ($80)
Drive: Samsung 5 star dvdr drive ($25)
Wifi: Asus
ASUS(PCE-N15) maximum performance Wireless-N Network Adapter ($28)
Is this a good build? Thanks for the input
Crossposted in General Hardware
mfenn
General Hardware Moderator
SteveGrabowski
8,774
7,402
Wifi: Asus
You're already at $590 without a case.
Ken g6
Moderator
Dec 11, 1999
16,648
4,590
75
It looks like you want to play older games that do better with one or two fast cores. Unless you're a really good overclocker you'd probably do better with Intel.
I have [thread=2389797]a thread with suggested $500 PC builds[/thread]. Do you want to overclock? If so, you might do better with the G3258 build (link near the bottom); otherwise aim for the i3 build. A DVD drive and WiFi adapter appear to bring your build close to that $550 limit.
Edit: By the way, where are you getting Windows for $80?
Status
