Hi all,
I was in the process of building my own PC. Hope you could spend sometime and help this noob out 😱 I am not going to OC..but rather aim for a stable computer that could play game. After a while searching...I got some question..worrying about that could my the items that I have selected will match with each other..or will the conflict ?(compatibilty)
*Sorry if I ask too much 🙁 ..I tried to search around but the answer varies so I taught your oppinion worth more !
This is what I have in mind. If there is any better deals or compatibility issue please voice them out 🙂
*I plan to use this computer for multitasking stuff such as ide encoding and editing.Will be doing some MAYA and 3Dmax too but Quadro is expansive X|
Motherboard not sure (Fatal1ty AN8 SLi)
* I heard that with Fatal1ty AN8 SLi you have less option RAM(expansive) to choose with. If using DFI lanparty, you could get more option RAM to go with and further its cheaper. Is this tru, could someone explain ? I saw Abit AN8 32X, which has Silent OTES(heatsink) compared to OTES(loud ?), is it worth to spend more ?
Opteron 170
After long browsing, all manufacturers just state the mobo support socket 939/athlon 64. Does it Athlon 64 or socket 939 means it will support Opteron Processors ?
Is it worth it to get Opteron 165 and overclock it ?
XFX GeForce 7600GT 256MB DDR3 Extremex2(wanted to SLI)
There are 3 version Extreme XXX, Extreme and the normal edition. Which is more best performance/value ?
OCZ OCZP4002GK 2GB Kit DDR400 PC3200 Platinum XTC Edition
Is there any better options ? like better performance/value ?
Fortron 600watt
I could get it for $105. Any better options ?
Hdd 4 piece (plain to RAID)
SAMSUNG SpinPoint P Series 160GB 3.5" SATA 3.0Gb/s
Model #: HD160JJ
Summary
Fortron 600watt
Abit Fatal1ty AN8 SLi (any other suggestion?)
Opteron 170
OCZ OCZP4002GK 2GB Kit DDR400 PC3200 Platinum XTC Edition (any other suggestion?)
SAMSUNG SpinPoint P Series 160GB 3.5" SATA 3.0Gb/s X4 (RAID)
Thanks in advance. hope I dont miss out anything 😛
Opteron 170
Fortron 600watt
Model #: HD160JJ
Summary
Fortron 600watt
Opteron 170
