I'm looking to buy a new system and would appreciate any comments/feedback/recomendations you might have.
I plan to use the system for some gaming (HL2, CS) but mostly for video editing (from DV tapes) and video conversion (various formats to mpeg2).
Based on what I'll be using this system for, would you recommend I go with AMD or Intel? Also note that I don't plan on overclocking at all.
Here is something a local shop is offering (in Canadian $'s):
Case/Power:
Enlight Mid Tower ATX Case w/ 7 Bays w/o Power Supply, Black
Enlight 450W ATX Power Supply
*I plan to upgrade to Antec® Sonata Piano Black Quiet Mid Tower w/ 380W Power Supply
Motherboard:
Asus® P5GD1, Socket 775, Intel® i915P Chipset w/ PCI Express x16 (ATX)
OR
Asus® A8N-SLI Deluxe, Socket 939, NVIDIA nForce®4 SLI? Chipset w/ PCI Express x16 (ATX)
Memory:
512Mb DDR SDRAM Ram Module, PC3200
Drives:
200 GB Western Digital® Cavier® SE SATA-150 7200RPM 8Mb OEM
Panasonic 3½ in (1.44Mb) Floppy Disk Drive, Black
Sony 16X DVD-ROM Drive OEM, Black
Sony DWD22A Dual Layer DVD+/-RW Drive (IDE) OEM, Black
Video:
Asus® Extreme EN6600GT/TD - GeForce? 6600GT GPU w/128Mb DDR3 & PCI Express Retail Box
*Is this a good card? For what I need, should I upgrade to something else?
Monitor:
Viewsonic® VP191b, 19in 1280 x 1024 Digital Active Matrix TFT LCD, Black
Other:
USR® / 3Com® 56K Fax/Modem (PCI) v.90
On-Board PCI Sound built-into motherboard
On-Board 10/100Mb Lan built-into motherboard
KeyTronic® KT800 Keyboard w/ Windows keys, Black
Logitech® Blue Optical Mouse (OEM) w/ Wheel
Economy TechCraft® Turquoise Mouse Pad
MS Windows® XP Home w/ CD & Manual (OEM) <-- I will upgrade to XP Prof.
Logitech® X-530 Speaker System (Retail Box)
Arctic Silver® Thermal Compound (3g Tube - multiple applications)
Blue Cold Cathode Neon Light
5 Year Labour & 1 Year Parts Warranty
Finally, for the amount of performace gain you get, what would be the best value?
AMD Athlon 64 3200+ ............................... $2264.99
AMD Athlon 64 3500+ ............................... $2349.99
AMD Athlon 64 3800+ ............................... $2799.99
AMD Athlon 64 4000+ ............................... $2899.99
Intel Pentium 4-530 ............................... $2129.99
Intel Pentium 4-540 ............................... $2174.99
Intel Pentium 4-550 ............................... $2249.99
Intel Pentium 4-560J .............................. $2439.99
Case/Power:
Motherboard:
OR
Memory:
Drives:
Video:
Monitor:
Other:
