I would like to build a new PC.  I have done so in the past, but I have been so far out of the loop as far as the new technology that's out, that I have no idea of what to buy.  So any help you can give would be great.  I would like to stay under a $1,000.  I filled out all the questions below.  I need everything, Motherboard, Ram, CPU, CPU Fan, Power, Video Card, Hard Drive, Case and anything else I might need.  I could figure out what I need on my own, but after reading all the post and threads, there are a lot more people out here that know I lot more then I do.  Which would help me get what I need without going over board and spending needless money.
PLEASE when you POST threads asking for input on system builds tell us...
1. What YOUR PC will be used for. That means what types of tasks you'll be performing:
Gaming and Photo editing
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread:
Under a $1,000
3. What country YOU will be buying YOUR parts from:
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc:
What ever is good and stable
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are:
The only parts I will be using from my old PC is Monitor, DVD Burner
6. IF YOU have searched and/or read similar threads.
7. IF YOU plan on overclocking or run the system at default speeds:
I have overclocked before, so I would like that option.
8. What resolution YOU plan on gaming with:
What ever is good
9. WHEN do you plan to build it?
I have money in hand.
10. Don't ask for a build configuration critique or rating if you are thin skinned.
I dont have thin skin, nor Im I thin, period.
Under a $1,000
USA
What ever is good
 Facebook
Facebook Twitter
Twitter
