Hello to all & thanks in advance.
Right now I'm using an AMD Athlon XP 2100+, 1.73GHz, MSI KT4V Mobo, 1.5GB of Ram.
I've started acquiring pieces to build a new PC, but I'm unsure what to get in terms of a CPU & MoBo.
Here's what I have already:
Antec SLK 3700 case w/ 350w p. source
2x Maxtor HD's
Sound Blaster Audigy2 Sound Card
Radeon 9600se 128mb
NetGear PCI Adaptor
1.5GB Of Ram (that's in my current PC)
I don't play games on my computer, but I still want a decent machine that's an upgrade from what I'm using. I'm considering these items:
AMD Athlon64 3200+ & MSI K8N Neo4 Platinum.
Is this a nice upgrade over my current set up? Is it a good bang/buck ratio? I'd like to stay under $350 (if poss).
Also, is there a way to hook up 3 HD's into a system?
Again, thanks for any direction you can provide.
2x Maxtor HD's
Radeon 9600se 128mb
NetGear PCI Adaptor
