Hello I'm building a PC for my brother so he can do homework and play a little bit of games on it.
7. IF YOU plan on overclocking or run the system at default speeds.
Default
If possible I'd like to use Bitfenix Prodigy case @79.99 (Yes mITX form factor)
I wanted to get Asus P8Z77-I @189.99$ but it's quite expensive. I already have a couple things in mind like 8GB Kingston Hyper X @39.99, Western Digital 1TB@79.99
Starcraft II, Diablo III, word processing1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
600~700$2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Canada (NCIX)3. What country YOU will be buying YOUR parts from.
Intel, nVidia,4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
keyboard, mouse, monitor, speaker5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Default
1080p8. What resolution will you be using?
As soon as I know my build9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
