Help building $2000 Adobe CS6 rig w/o monitor
jdb264c
Hi, I would love the communities thoughts about this build:
I'm in the process of building a new computer for my girlfriends job, with the following principles:
1. She will use it for Adobe Photoshop CS6, InDesign CS6 and Illustrator CS6.
2. She will NOT use it for video rendering.
3. She will NOT use for gaming.
4. Her only knowledge about hardware is that "Macbooks look good" so I'm thinking that it has to be really silent and look rather distinguished (i.e. no flashing lights etc).
5. The budget is rather flexible would the absolute maximum would be $2000.
She's already got an Samsung 27" SyncMaster SB970D as a monitor so there's no need for a new one.
I find the absolute hardest part being deciding between AMD/Intel on the CPU part, and AMD/nVidia on the graphics part. It seems, correct me if I'm wrong, that AMD uses OpenGL/CL in a way that for the moment would be an advantage over nVidia but I'm even less certain when it comes to the CPU. Advice appreciated!
So here's my thought and suggestions:
Case:
Fractal Design Define R4 :: $135
PSU:
Seasonic x850 850W :: $290
Fans:
Something from Fractal Design or Scythe. As a CPU fan maybe the Noctua NH-U9DX for $96
System HD
Samsung 830 Series MZ-7PC128 128GB :: $128
Scratchdisk for Adobe programs:
Samsung 830 Series MZ-7PC064 64GB :: $92 (Or maybe switch the system and the scratch disk)
General HD
Western Digital Caviar Black WD2002FAEX 64MB 2TB :: $223
CPU:
AMD FX-Series FX-8150 3,6GHz Socket AM3+ :: $230
Motherboard:
Asus Crosshair V Formula-Z :: $323
Graphics card:
Some Radeon 7970, not quite sure yet, possibly ASUS. :: Approx $540
RAM:
G.Skill TridentX DDR3 PC19200/2400MHz CL10 2x8GB
So, what should I change? Gladly anticipating the verdict from the forum!
Regards
Johan
T_Yamamoto
14,999
772
Here's a rough build
i7 3770k
Z77
16gb 1600mhz 2x8
64gb scratch
128gb programs
1tb file
500watt PSU
KeithP
5,630
177
How much data does she keep on the system at any one time?
What about backing up the data, local and offsite?
What about a calibration device for her monitor?
Just some extra things to think about if you haven't budgeted for them separately. And unless you can guarantee your support services 24/7 it would probably be wise to look at a Dell or similar. At the very least, if she is busy enough, you may want to budget for a light duty back up system in case the main computer goes down.
-KeithP
jdb264c
-KeithP
Great points, thank you!
The amount of data isn't that great at the moment but she will soon start putting in loads of raw files so I'm guessing she'll need to expand the HDs within half a year.
She's got a calibration device already but thanks, a very valid point!
SKORPI0
17,073
1,200
Don't forget to add about $140 Windows 7 OEM and $700 for Adobe CS6 or else the build won't be doing anything at all.
So computer parts are $2057+software $840 = $2897. ;)
jdb264c
Hahaha, good points!! Luckily, her boss hook her up with the Creative Cloud!
Insert_Nickname
4,068
653
If that machine is going to be used for serious work, I would take a good long look at the Xeon E3-12xxv2 series. These are Intels LGA-1155 workstation CPUs, they have all the features of the i7 series at cheaper prices...
As you can properly work out, I would not use a regular desktop CPU for this kind of serious work. Especially when down-time can cost on the bottom line...
The only problem is that you need a main board that supports one, like this one;
http://www.asus.com/Motherboards/Intel_Socket_1155/P8C_WS/
my 2c
jdb264c
my 2c
Very interesting indeed! Thank you for that, I had never heard of this but will look into it immediately.
DSF
4,902
Where are you buying your parts? Those numbers look expensive.
Also, do you have any particular reasoning behind your choices? The PSU and motherboard are unnecessarily expensive by a factor of 2-3.
jdb264c
They will be bought in Sweden, and that can unfortunately not be changed.
Yes, I've received some massive responses over at Tomshardware mentioning the same thing, that the PSU and MB is overkill, so I will change these. Thanks for answering!
cantholdanymore
447
jdb264c
For CPU you need to go Intel here:
http://www.hardwareheaven.com/reviews/1482/pg7/intel-core-i7-3770k-ivy-bridge-processor-launch-review-cpu-performance.html
PS (don't know about the other software) doesn't need a powerful card, she can do with the iGPU.
It looks from the specs of the monitor that it supports 10bit color. If this is important THEN she'll need a pro graphic card with 10bit support. AMD firepro or nvidia quadro.
Great link, it helped a lot convincing me to go Intel!
Yeah, original specs said 10bits but it's actually "just" 8.
T_Yamamoto
14,999
772
vailr
54
Hackitosh is a lot of work for a first time builder.
Maybe so, although the OP didn't specifically say as much, concerning previous build experience.
The same hardware used in the referenced link would still work well as a Windows-only machine. Adding a 2nd hard drive (or SSD) and installation of OSX could optionally be added at some future time.
mfenn
22,400
www.mfenn.com
Macbook Pro + DisplayPort cable? :awe:
But seriously, that is a viable option if she works in a Mac ecosystem (lots of photog's do) and/or wants to pick up and edit on the go.
ASK THE COMMUNITY
