My buddy in the lab next door is building a new computer, which will be used almost exclusively for running some custom fortran code which plugs and chugs numbers. It's not graphically intensive.
He's got a budget of like 2 grand, so I figure one could put together a pretty special machine for the purpose.
What pieces should one look for?
Is fast memory and a fast processor all that's really important here? Do intel/AMD have a signicant difference in number-crunching abilities?
It's only a single processor program. But would a 64-bit processor help anything, unless you're dealing with numbers bigger than 32 bit?
Does the motherboard matter, as long as it supports a fast enough bus speed to keep up with the rest?
