I have a Lian Li PC 2100 case, with the basic 120mm fans, and the exhaust blower fan that came with the case.
Here's an overview of the case's heat specs: http://www.lian-li.com/v2/en/produc...ex=137&cl_index=1&sc_index=38&ss_index=95&g=t
I'm usually running 8-12 hard drives in the system, 4 are 74gb raptors that normally run a little hotter than others (these are placed at the top since they produce the most heat).
A couple minutes after I turn on the computer from a cold start, my HDD temps are around 33 C. 5-10 minutes later, they are up to 41 C. Then during normal conditions, they reach up to 53 C
I'm thinking that it may be wise to replace the 120mm fan that blows air from the front of the case (left of the hard drives) to the rear of the case.
Anyone have any other suggestions of what to do to lower these temps?
My Q6600/motherboard/ram is around 33 C, both videos cards (6600GT & 8600GTS) run around 67 C.
Here's a pic of the HDD area, followed by an overview of the entire case's setup:
Full case view from the side (left side is the front).
