help !!!!!!!!!!!!!!!!!!!!!!!!!!!! bois flashing problem abit kt7a-raid
twp243
4
System:
1.2gig t-bird @1.2
2 20 gig w-d 7200 hd's
1 40 gig w-d 7200 hd
S-B live 5.1 platinum
256 microm mem pc-133 @ cas 2
ATI radion 64 meg ddr video card
i-omega 12x10x32 cd-rw drive
Here is the problem:
Flashed the bios to the yh version and now it will not boot or even post. so now what do I do???? am I screwed??? any advice would be greatly helpfull
:| :confused: :disgust:
Mem
21,476
13
I know somebody that did the same thing, anyway reset the the CMOS it should work,funny enough he was flashing the same BIOS version as you,he reset the CMOS which worked for him & was brave enough to try flashing the Bios again(same bootdisk) & it worked second time round.
forkd
1,122
Same issue with the same upgrade. I had to flash, clear CMOS, flash, clear CMOS a few times before it finally became clear I didn't destroy my chip. If all else fails you can "borrow" another chip boot into the bios, shut down, put in your messed up one and try to flash again.
This site has been very helpful to me on this board.
KT7A help page Unofficial
