HELP! BLUE SCREEN!
BeLikeMiKe716
Okay so family member requested me to fix his computer and tells me he gets this blue screen whenever the computer starts handling load:
Kernel_Data_inpage_error
*** stop:0x0000007A (0xc03DD388, 0xc000000E, 0XF74E2642, 0x51E41860)
*** ftdisk.sys _ address F74E2642 base at F75D8000, Datestamp 3b78419
I searched it and got a general problem description but was wondering if the specific problem can be identified. He has two monitors hooked up to it running a P4 and WindowsXP.
I attached two of my monitors and tried to simulate load and surprisingly the computer never had a problem. I dont know why he would experience blue screens all the time and i dont.
Also I looked inside the case and noticed that he is running with a 380W power supply. I think its too low right? And also instead of a 24pin power connection to the motherboard which it has, its powered only by a 20 pin cable from the power supply. Does that do anything also?
Please helpful input would be greatly appreciated.
lamere
479
hmmm.....you might as well called fire in a place thats not burning and this is no 911 emergency station:roll:
disk drive possibly having a bad block or bad controller could be the problem.
themisfit610
1,352
380W should be plenty - as long as he's not running massive hardware. This issue is most likely related to memory / hard drive issues. Test his RAM and hard drive.
Could be drivers, or just a b0rken OS.
~MiSfit
BeLikeMiKe716
Also I looked inside the case and noticed that he is running with a 380W power supply. I think its too low?
And also instead of a 24pin power connection to the motherboard, its powered only by a 20 pin cable from the power supply. Does that do anything also? The motherboard has a 24 pin connection but only 20 of it is filled with the psu.
