Help: Best bang for the Buck Card for a x38 Asus MOBO
paniccode
7
Hello,
Can someone help me spec out a Video Card for a ASUS P5E LGA 775 Intel X38 MOBO. I am a Moderate gammer, but not hard core, I am not going to overclock the system so I need a good card for general use. So in your opinion what will be the best bang for the buck.
I will be running Win XP pro, unless someone can give me a real reason to switch to VISTA.
thanks for your time.
krnmastersgt
2,873
I do suppose the better cooler and the fact that's dual slot is probably a huge plus, but how's the warranty in case something craps out?
ajaidevsingh
563
If you a light gamer get the 3870...It eats a lot less energy and has a better heatsink than stock 8800 Gt's...!!!
