I just got a new AXIA 1000mhz retail and I installed it onto an MSI K7T Turbo that I baught off the forums.Here's the problem in my biosI the lowest I can set the clock is 133
and my CPU is a 200FSB so needless to say well it overclocks to 1333 real well as I am currently useing it (of course thats not the problem LOL) the problem is heat it is running at default voltage thats cool but all I have is this retail HSF. right now as I type it is at 52c.I'm affraid I'm going to burn this up when I start playing my games should I be worried or should I run 3DMark 2000 and see if it locks up and or what the temps running it are?please help I can't afford to burn this up.If I do I'm screwed with no PC for a while.this is the first time I ever ran an athlon and well 52c idle seems hot to me.
EDIT: MY CASE temp is like 23c
also my bios shutdown temp is set to 70c the lowest will that keep me safe?
HELP ME OUT PEOPLE
Thanks people and thanks to mikendi I found out there's a jumper on the board to set it to lower FSB duh
HELP ME OUT PEOPLE
