just built a new computer (epox 8kha+ with an amd 1800+ (but it was fried so im using a duron)) and i have an audigy platinum in there. It did not install any sort of drivers during the install of windows XP so i was wondering what i can do to get these drivers? I tried installing the ones off of the cd and then downloading the update at www.soundblaster.com/support/winxp but it created problems with mscovert .dll file on boot up and i had to reformat. What is the proper way to install these drivers and where can i find them?
Also, can i restore to a system restore point without being able to boot into windows? maybe off of the cd or something?
Weston
Weston
