I just bought essentially a new computer from newegg.
I got a MB ASUS K8N-E DELUXE NF3 RTL
VGA PWRCLR|R98-PC3F/128BIT RTL ATI video card
CASE ROSEWILL|TU-155 BLACK 400W
CPU AMD 64 |3200+ ATHLON 64 512KRTL
2 DDRAM512MB|CORSAR64X64 VS512MB400
I have an 80 gig hard drive which I had from another computer with windows xp on it.
I put it all together and I've been having all kinds of problems. What I'm finding right now that?s annoying me is when I plug in my usb wireless D-land card and it's not getting any juice. I plugged it into the front usb port and when I did that it restarted my computer. I'm thinking that maybe I have a really bad power supply and maybe I should go out and buy a new one. I'm really new to all this so I'm not sure what to do. So any advice you may have at this point would be great. What are some steps I can take to make sure that the power supply unit I have is enough for all I running? Also I found a red switch on the back of it where I can change from 115 to 230 does any one know what that does? I tried switching to the 230, but the computer right after it powers up powers back down.
Thank you guys
Dax
Thank you guys
Dax
