I have: Asus CUSL2-C, Cel 633a, Golden Orb. FSB set to 100. Voltage set to 1.75.
Not sure what stepping (c0 vs b0?) I have.
Question 1) Motherboard Monitor shows me two temps on the left. One was around 80 F, and the other was around 40 F. I'm assuming the 40 F is the CPU, because of others mentioning there OC's 633 running around 40 degrees. Is this a correct assumption? IF this is correct, what is the 80 F temperature? The Orb is plugged into the CPU fan header located by DIMM #1.
Question 1a) Should I instead use the motherboard monitering tool that came on the Asus CD? Might be a dumb question, but my first time around installing it, it came up with errors, and somehow messed things up such that I had to reformat. IF I should use it, does it require the LCM stuff (remote host updating, i think) in order to install? I ask this because I believe the error I mentioned earlier was "cannot find LC??? something".
Question 2) Is 1.75 V an okay temp top run this CPU at? Stock voltage is 1.65?
Thanks for all and any help!
