HELP!!! Antivirus ??s, Xp 32bit, Vista 64bit, Compatability ?s HELP!
sparks5248
:confused:
Mobo: Biostar TA790GX A2+
Processor: AMD Phenom Quad Core 64
OS: Vista 64 bit
OK, so I just found out that the installation program's I have to put on my computer for work are not compatible with Vista 64.
I must have either XP or Vista 32 bit editions. Those are the only OSs that our Citrix & VPN are compatible with.
My questions are, is XP 32 compatible with a 64 bit Processor, I believe it is but am not entirely sure?
Also, This damn software I have to install uses McAfee & a Symantic Client that is such serious business that I cannot even remove it without a Password, or to entirely rewrite my current drive with Vista. I've checked the registry & no hint of a pass code key, nothing. The default in the program files does not work & it's slowing my computer down. I am going to have Tech support remove it because they will not tell me the pass code. SOOO I am going to add another HD & OS, but my question....
Can I run Norton with my Vista, & this McAfee Symantic S!&# on XP HD Only? IS this possible? I love my Norton on my vista, it's soo fast, I don't want this McAfee Symantic crap stuffing up the Personal part of my computer!
Schadenfroh
38,416
4
Welcome to Anandtech:)
Yes, I used 32-bit Windows and Linux on an Athlon64 for years.
Symantec has 64-bit versions of their software available. At my university, the 32-bit and 64-bit clients are separate (and they do not give us (students) the 64-bit version), but they do exist.
Symantec is the company that makes Norton and they are a competitor to McAfee.
sparks5248
I understand, "Symantic & McAfee" are whatever, however they are required on the XP i will run. It's an insurance writing program to gain access to a Nationwide Network, so Thanks you've answered all but one of my Questions.
Can I run 2 separate Antivirus Programs whith 2 OS??? Can I run Norton on the HD w/Vista & this other stuff on the HD with XP???????????/
lxskllr
60,471
10,850
yes
bsobel
Moderator Emeritus<br>Elite Member
Dec 9, 2001
13,346
Yep
Yes. What exactly is the McAfee Symantec 'stuff'. We are competitors, are you trying to say your running software from both at the same time?
sparks5248
Thank you guys so much, I wanted to get that straight before I hit Newegg. I know it's confusing the Symantic McAfee stuff, it comes in a package to download a network capability, so I can access the Nationwide Insurance Network through the Internet. I don't know how they both run, but they are both in the package & must be installed to have acess to the Company Network. I will install those on the HD with XP. Confusing, I don't know. There is this weird Symantec Agent that as I said previously cannot be removed without a pass code & also McAfee software in the Package. I had to completely Un-install my Norton Package 09 to add this stuff & It's making my computer run very slowly... Anyways, thank for the help!
SickBeast
14,377
19
You know, there are freeware programs like Avast that will do the same thing as Norton. No need to spend money. You can get freeware applications for just about anything when it comes to office-type applications.
VinDSL
4,869
www.lenon.com
Originally posted by: Tbirdkid
1 word.. avast.
I love avast!
Especially the avast! screensaver - scans your drives when your your machine is idle.
Heh! A lot of ppl don't even realize this avast! feature exists...
